2003-11-12 7:31 PM
2003-10-31 3:58 AM
Can anyone help with the software for the early ST S6 ICE Emulator.
The model No is:- ST6- MAINFR Any help gratefully appreciated. John[ This message was edited by: johnbscot on 31-10-2003 17:29 ]2003-11-05 8:38 PM
The emulator you are using is very old(around 10 years) and is not supported by ST now.The emulator may have difficulties with todays high speed PCs. So i will suggest you to use the latest Emulator for ST6(ST62GP-emu2) that support all ST62 devices except ST624X and ST628X.
2003-11-12 7:31 PM
Hello, I found the debugger for this tool. I attach it to this mail, but as the moderator said, it is quite old, then for example the connection is serial (RS232) and this debugger is under DOS.
Pay attention, I hope you have the associated connection cable, othervise you must cross 2 and 3 (RX, TX) and ''say'' to the PC that mainframe is ready (wirth RTS, CTS ...) Best Regards ________________ Attachments : st6ndb.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0JA&d=%2Fa%2F0X0000000bX5%2FoRVhPZ9o1NvxAs94c.JDQLfLFYgJr7bBoj02N4OIx_A&asPdf=false
