IAR workbench & JTAG for STR71x microcontrollers?
vinodkumar
Posted on December 10, 2004 at 12:34
vinodkumar
Posted on October 29, 2004 at 04:03
I am using IAR workbench and JTAG, for philips LPC21x microcontroller.
But I am unable to use the same for ST microcontroller STR71x.
Is there any additional settings required to use the same IAR workbench & JTAG for STR71x microcontrollers?
Vinod
vinodkumar
Posted on October 29, 2004 at 08:10
Hi Ibtiss,
Thanks for ur response,
I have tried with IAR Jlink, but the error message was ''invalid core ID''
pls give me more detais about changing the startup files and the map files.
regards
Vinod
vinodkumar
Posted on October 29, 2004 at 12:50
Hi Ibtiss,
I have tried to run the example as it is,
and replaced lnkarm.xcl file with the given one.
but while making the project I am getting the error as below
''Error[e6]: Program module ?RESET redeclared in file D:\Program files\IAR
Systems\Embedded Workbench 3.2\ARM\LIB\dl4tpainl8.r79''
Vinod
