2009-10-13 08:01 AM
2011-05-17 12:59 AM
You disable ACK before you (re)send the address with read option; in fact, at the very beginning 8-)
2011-05-17 12:59 AM
Hi all,
I am not able to perform write after 1 byte read from EEPROM using str912. When to disable ack config in case of 1 byte read? As per the reference manual it should be disabled before reading second last byte. Thanks and Regards Sai
