I2C interface
babidesai123
Posted on August 07, 2003 at 06:34
I2C interface
babidesai123
Posted on May 17, 2011 at 11:55
Hi.
we are trying to interface upsd 323X with Digital Temp sensor (LM75) I2C based.
we have gone through the programmer's guide for I2C.We would like to know if any example codes are available for the same in assembly language.
Thanking you,
Purvi
chris_baragnon
hi,
if you are using keil compiler you can see the assembler code generated by the C code in the debugger with the disassembly window.
totof.
