2004-02-23 04:31 AM
2011-05-17 02:58 AM
On a particular design, I have componants with different Bitrate under i2C such as:
1 24C02 E2PROM at 400 KHz, 2 X UPSD up to 750 KHZ using 24 Mhz XTal, 1 DS1307 Clock at 100 Khz. does anybody know this: Can I use different bitrates : 750 Khz to communicate between UPSD, 400 KHz from upsd to E2PROM, 100 Khz from UPSD to Clock ? Or am I obliged to run at minimum speed 100 KHz ?2011-05-17 02:58 AM
You will have to comply with the minimum speed device, eg. 100KHz.
I2C devices are only upwardly compatible. A possible solution is bridging - have a look at the latest I2C spec which mentions this. Regards sjo[ This message was edited by: sjo on 23-02-2004 17:44 ]2011-05-17 02:58 AM
Thank you for your answer.
