2004-07-19 03:14 PM
How to read stable a/d converter value? Can any ST engineer give me some advice?thanks!
2011-05-17 03:02 AM
2011-05-17 03:02 AM
Please send your question to
mailto:apps.psd@st.com
. Provide information about the board you are using (DK3200 or your own), version # if DK3200, oscillator frequency, your settings, what voltage you are measuring, what reading you expect and what you are getting, and anything else that you think is relative. Also provide the following information so we know a little more about you: Name Company Name Phone Number Location (City, State, Country) Production uPSD part number (3233, 3234, etc.) Application Projected annual volume (units) Production start date Thanks, uPSD Applications Engineering2011-05-17 03:02 AM
I have written am email about a/d problem to ST technical support,I am looking forward to his reply,thanks!
2011-05-17 03:02 AM
hi
You can''t get a stable A/D reading. There is a prblem in same version of uPSD.2011-05-17 03:02 AM
uPSD3334 Rev C silicon is now available and is errata free. Rev A has some accuracy issues when using the prescaler. If you limit the MCU clock to 16MHz and use an ADC prescaler divisor of ''1'', you should be able to achieve +-2 LSB, otherwise the accuracy will be around +-4 LSB.
Rev A silicon has date codes of 5A5010332, 5A5010338, 5A5010345. Please contact your local sales representative or distributor to obtain rev C samples. If you have a DK3300 with rev A silicon, please send a request for an updated board with rev C silicon tomailto:apps.psd@st.com
. Be sure to include: Name Company Name Phone Number Shipping Address (Address, City, State, Country) Production uPSD part number (3333, 3334, etc.) Application Projected annual volume (units) Production start date Thanks, uPSD Applications Engineering2011-05-17 03:02 AM
Rev C silicon is used iin my project, and OSC is 18.432Mhz, I modified the turbo_upsd.h provided by ST,But the accuracy is about +/- 20 LSB ,not +/-2 Lsb, in fact , I want to know why upsd33xx can't provide separate analog ground and Vcc, how to deal with ground pins in Upsd while layout. All ground pins can be connected with a ground plane and don't need think about analog and digital ground?
Thanks!
