How can I get the ST10 flasher tool?
XS.1
I need S10 flasher tool to program my ST10 chip
hamdi.najoua
Please find it enclosed.
Najoua.
10 REPLIES 10
https://community.st.com/s/question/0D50X00009XkcTjSAJ/st10-flasher
Version 2.3G is posted here, not sure it will run under Windows 10, this is at least 14 year old software
hamdi.najoua
Najoua.
SMsp.1
thanks ill check it
PMaha.4
Pls
Guide me.. Which programmer is supposed this 10f flasher software
Please try to formulate coherent sentences.
It's for programming ST10F27X MCU via the serial port, boot strapped into loader mode.
Are you using these old MCU? Do you have a contemporary computer system to run it from?
Any people you work with familiar with it, or involved with the design / programming?
https://www.st.com/resource/en/application_note/cd00052666-programming-the-st10f27x-embedded-flash-using-the-st10flasher-tool-stmicroelectronics.pdf
Hello,Could you send me the link of Tool Version 2.3G.​Thanks.
*Edited by moderation* Please, do not share personal information in the public forum.
@Laura C.​ can you fish this out of the older forum instance? This looks to have gotten lost when the forum transitioned at some point. Thanks, -Clive
This should be V2.2
Hi @Community member​ ,
After checking, this cannot be retrieved from the previous forum.
Thank you
Laura
