2008-06-25 05:25 PM
2011-05-17 12:53 AM
2011-05-17 12:53 AM
HI all.Does anybody know/using HiTOP IDE then please help me.
Tell me the procedure to create new application.I face some problem with creating elf file,symbol preprocessor.I fail to generate .elf, .htx and .sym . Ide ask for elf at start only. So, if anybody knows tell me the complete procedure to create new project , then new application, IDE configuration, compilation and linking. Best regards Sai2011-05-17 12:53 AM
Thanks for reply
But didnt got any help from it.There is no option ''using projects in Hitop'' as such. Iam using HiTOP52-ARM Version-05.20.0310 So please give me further detail. Best regarg sai [ This message was edited by: sr_shinde on 24-06-2008 12:06 ]2011-05-17 12:53 AM
the ''using projects in Hitop'' is a window which appears when opening Hitop. you can find all the necessary information in the Hitop online help(in the section ''getting started->starting up the system->starting hitop'' mgd,2011-05-17 12:53 AM
Hi
''using projects in Hitop'' window doesnt appear when i open Hitop. i am using evaluation version Regards
