Global variables ? How??
amoreno
Posted on January 02, 2008 at 05:18
3 REPLIES 3
rasty
Posted on January 01, 2008 at 08:05
you can define it as ''int fofo;'' in one file and as ''extern int fofo;'' in the other.
There is more fancy way to do the same - via include file.
If you would try Google for ''creating global variable in c'' you would be surprized with the results :)
http://www.imada.sdu.dk/~svalle/courses/dm14-2005/mirror/c/
amoreno
Thank you for your reply.
Now it's working properly
Regards.
ALFA
amoreno
Posted on December 31, 2007 at 09:03
Hello all,
My question is easy for you, sure.
How I can create a global variable ? (I use IAR Workbench)
That's, a variable that I can see in main.c and in 71x_it.c (interrupt routines).
How can I do it??
Yes, I'm totally newbie.
Thank a lot
ALFA
