2005-06-10 07:00 AM
Flashing STR711 with GNU Toolchain & JTAG-Wiggler
2005-05-20 05:42 AM
i want to programm the STR711 via a JTAG-Wiggler and GNU-Debugger/Insight. Is it possible to programm the internal flash directly using the Toolchain from GNUARM? Or do i need to programm the flash by executing a ''flashing application'' from the internal RAM? If so, is there any (free!) code for doing this offered by ST? Or a free flashing-tool? Thank you ! Regards, Chris2005-05-25 10:29 PM
If you download our free toolchain www.st-angliamicro.com/software.asp we provide a flasher utility for the Wiggler. Best Regards, Martin Davey. [ This message was edited by: MD on 26-05-2005 10:59 ]2005-06-10 07:00 AM
thank you very much :)
im using your idealist software right now ....
