Fat file system for SD card
mtraman
Posted on August 07, 2007 at 04:32
5 REPLIES 5
mtraman
Posted on May 17, 2011 at 09:41
Hi all,
the sd card file system has been ported to str9
it is based on the embedded filesystem library from sourceforge
the compiler is RealView
[ This message was edited by: tvikram on 19-04-2007 07:04 ]
craig239955_st
Thanks a lot !! :D
Luc
gkruger
Thanks tvikram!
I am getting an error when compiling. The error says that ''A LABEL was found which was in no AREA'' and pointing to the first line in the scat_ram file. Is there a special way that you need to add the scat_ram.scf file, or something that I need to set?
Gert
animev09
I use MDK-ARM eval which does not allow to use scatter-loading description files. Is there anyway to modify the start up code without using scatter file?
John
gkruger
Hi John,
I think the original project for the lpc2000 didn't use a scatter file. Maybe worth looking at that. It is available at
http://sourceforge.net/projects/efsl/
I got the previous error because I didn't load the scatter file correctly, but now I am getting other compiler problems(entry points etc). I don't have enough time/experience to find all the problems and am going to code the parts I need myself as I only need limited functionality. Will try and get the efsl system up an running in my own time :)
Gert
