external RAM: 16Bit-Write-Access dont work
siegmund
Posted on May 18, 2004 at 04:53
4 REPLIES 4
siegmund
Posted on May 17, 2011 at 11:35
hello all,
i have connected external RAM to the ST92F150CV as shown in Figure 74 in Datasheet V1.5 (MC=0).
nearly everything works, even programm-execution, but 16bit-write-access doesnt work.
the logic-analyzer shows, that signal E/ (from ST9::A21) and signal W/ (from ST9::RW\) dont change beetween both 8bit accesses.
but the RAM needs a change, either the E/ or W/.
what is wrong?
thanks a lot!
attached: picture from analyzer, shows first 8bit-write access and later 16bit-write-access (programm-execution from same RAM)
[ This message was edited by: siggi on 04-03-2004 13:51 ]
kapil
you can refer to AN1076 and AN1069, for external memory interface.
link is
http://cmg.st.com/stonline/products/cmg/mcd/familiesdocs.php?FAM=16
siegmund
hi chaps,
thanks for the application notes.
everything seems to be all right.
program-execution and 8bit read-write-accesses are working, even 16bit read-accesses.
only 16bit-write wont work.
any other hint?
thanks.
ritu
Hello Siggi,
If you are using external memory interface in mc = 0 mode. Both the signals /E and /rw should maintain the same value during the whole wirte or read cycle. (Both /rw and chip select should stay at low level in case of write cycle.) I wonder if you see any change in these signals during 8 bit write access ??
Also there seems to be some incohrence b/w the the signals shown in pic and their actual behaviour in mc=0 mode. First of all the name of the signals are different from mc= 0 mode (WEN in place of /rw and /OEN in place of /DSN). Also /WEN (/rw) signal should maintain the same value for the whole read/write access. (In case of mc =0) The one shown in the pic seems to be for mc=1.
Rds,
Ritu
