Error 51: Phase Inconsistency
stephendrummond
Posted on December 20, 2005 at 05:24
stephendrummond
Posted on December 07, 2005 at 18:45
Hi, I am using st7flite29 and ASM and I am getting phase inconsistency errors. I have read the manual but can not see how to locate where the error is occuring. There are about 25 errors but I suspect that once one error occurs then the rest will automatically follow. Any ideas?
Steve.
laurent239955_stm1
Hard to help !
Can you attach some files ?
You should be right a first error can cascade the other ones.
Did you try to remove some parts of the code to find where the error is coming from.
Best regards
Laurent
