Data EEPROM & Flash memory protection
nambip2
Posted on April 22, 2005 at 07:15
4 REPLIES 4
nambip2
Posted on April 17, 2005 at 13:55
I like to use the ST7FLITE09 .This has 128 bytes of data EEPROM which i like to utilize fom In application programming .At the same time i like to have the security enabled - ie flash readout proection.My doubt is that when i configure the device for flash read out protection will i still be able to use the data EEPROM for read and write?
venkateswara
Posted on April 19, 2005 at 11:16
Yes, You will be able to still write or read the EEPROM through In-application programming. The read-out protection is applicable for ICC mode. You can see the Flash programming refernce manual on the ST internet.
Hope this helps.
bye
venky
nambip2
Posted on April 21, 2005 at 14:19
Can you send the document number for the Flash programming manual ?
Prasanna
venkateswara
hi,
find the attachment i downloaded from internet...see page..
________________
Attachments :
1072800075.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Gf&d=%2Fa%2F0X0000000bWO%2FqW_tofKoCLG4gvzHNXclPy1857QNe1X7yYJPc.nFqAw&asPdf=false
