2005-04-21 05:04 AM
2005-04-20 11:36 PM
We are using M29W640DB bottom boot sector flash from ST Microelectronics for our MPC8248 based custom board. We are getting following messages while booting kernel. -------------------------------------------------------------------------------------------------------------------------------------------------------------------- jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0x0020 instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000004: 0x22df instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000000c: 0x0008 instead Further such events for this erase block will not be printed JFFS2: Erase block at 0x00000000 is not formatted. It will be erased . . . jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00de0000: 0x0020 instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00de0004: 0x22df instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00de000c: 0x0008 instead Further such events for this erase block will not be printed JFFS2: Erase block at 0x00de0000 is not formatted. It will be erased Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes Kernel panic: VFS: Unable to mount root fs on 1f:00 Rebooting in 180 seconds.. ---------------------------------------------------------------------------- Please see attachment for more information. Can you please tell me what the problem is and how to solve it? Regards, Dipen Patel ________________ Attachments : working_linux_flash1.TXT : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtqE&d=%2Fa%2F0X0000000aXe%2FoLAlOXSKSoY9kG9pCQ8JXTLc95IxiOtkcXi.MypAWPc&asPdf=false2005-04-21 05:04 AM
Oops I don't think you're at the right forum.
