Clock Cycle in str710fz2-16mhz crystal
ajsndd
Posted on September 20, 2006 at 03:55
4 REPLIES 4
ajsndd
Posted on September 19, 2006 at 08:26
Dear moderator,
We are using str710fz2 microcontroller with 16 MHz crystal.
Please help us to calculate number of machine cycles per second. And how can i calulate delay.
hichem2
Posted on September 19, 2006 at 08:46
Do you means by number of machine cycles per second the MIPS?
Could you please more clarify your question ?
With regards,
Hich
kleshov
Posted on September 19, 2006 at 15:49
The MCU contains complex circuitry to generate system clocks from the external clock input. How you configure them is up to you. Depending on configuration, clock frequencies can vary over orders of magnitude.
ajsndd
Sir ,
Actually we want to generate a delay of a specific time. We cant understand how much is the time taken to execute one instruction.
what is the minimum and maximum time delay possible
