Big arrays in st72f63 and Cosmic c
ohadr2
Posted on May 15, 2006 at 11:04
3 REPLIES 3
ohadr2
Posted on May 14, 2006 at 13:28
hello
i want do use big arrays and i can not compile this program.
my program is :
#include
char data1[200];
char data2[200];
void main(void)
can any one help me??
luca239955_st
Posted on May 15, 2006 at 06:34
with an array bigger than 128 bytes (actually, a little bit less) you need to make sure that it is allocated outside of page 0.
To do this, either select a model that put variables in the long range by default (any ''long'' model), or force your arrays in the long range by hand:
@near char data1[200];
@near char data2[200];
Luca (Cosmic)
ohadr2
Thanks a lot.
it is working now.
ohad.
