1.8V question
per2
Posted on November 25, 2004 at 13:31
1.8V question
per2
Posted on November 25, 2004 at 11:13
Hi there,
In the STR710-EVAL board document on page three it says
  • embedded 1.8 V voltage regulator for core supply (options to use the on-board 1.8 V regulator allows full speed operations,
    Since there's a starting bracket but no ending one I assume that there are some text missing, or was removed.
    I cannot find anything in the 'reference manual' saying that a ''better external 1.8V is needed''
    So what does this full speed operations mean?
per2
  • embedded 1.8 V voltage regulator for core supply (options to use the on-board 1.8 V regulator allows full speed operations,Thanx for the clarification
    /Yxan/
