SPC560BADPT100S usb/can flash
Jorge Suarez-Rivaya
Posted on March 31, 2017 at 23:23
Hi All,
I just got a SPC560 minimodule and a SPC56XX EVB motherboard. I find the getting started extremely vague. I got the serial cable and I have a serial/usb dongle to connect to my PC.
My questions are,
- what is the best method to flash let's say ChibiOS into the board?
- would it be via CAN? (I don't have JTAG yet).
- Is there any specific terminal program to work with? or should I do it via SPC5Programmer?
I have requested licenses for ST SPC5FlashProgrammer and SPCConnectExplorer but I have not received any answer with the Serial Number yet. What is the expected waiting time? How long that license last for?
3 REPLIES 3
Erwan YVIN
Posted on April 03, 2017 at 10:45
Hello ,
Did you have SPC5-UDESTK Token ?
Easiest and fastest way.
if yes ,
There is Application example inside Chibios + SPC560B Example (Generate and Compile)
  • You can use PLS-UDE to Flash (Link on Slide 4)
http://www.st.com/content/ccc/resource/sales_and_marketing/presentation/product_presentation/8b/be/80/18/4d/1c/4f/f0/SPC56%20Toolchain_overview.pdf/files/SPC56%20Toolchain_overview.pdf/jcr:content/translations/en.SPC56%20Toolchain_overview.pdf
   Install it and the driver associated
  • Reswitch to SPC5Studio to debug .. the flash programming should open
if not ,
Could you give me your Serial/Usb Dongle name that you use ?
   Best regards
                    Erwan
Posted on April 03, 2017 at 18:08
Hi Erwan,
Thanks for your answer.
No, I don't have a SPC5-UDESTK token yet. I ordered it but didn't receive it yet.
I don't understand why would you need the dongle name but it is  Keyspan serial/usb dongle.
regards,
Jorge
Posted on April 03, 2017 at 18:11
Also, requested last Friday activation keys for SPC5FlashProgrammer and SPC5ConnectExplorer through the installation wizard. I haven't received any email or confirmation or serial or anything. What is the normal process?
