SPC560BADPT100S usb/can flash
Jorge Suarez-Rivaya
Posted on March 31, 2017 at 23:23
Hi All,
I just got a SPC560 minimodule and a SPC56XX EVB motherboard. I find the getting started extremely vague. I got the serial cable and I have a serial/usb dongle to connect to my PC.
My questions are,
- what is the best method to flash let's say ChibiOS into the board?
- would it be via CAN? (I don't have JTAG yet).
- Is there any specific terminal program to work with? or should I do it via SPC5Programmer?
I have requested licenses for ST SPC5FlashProgrammer and SPCConnectExplorer but I have not received any answer with the Serial Number yet. What is the expected waiting time? How long that license last for?
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
3 REPLIES 3
Erwan YVIN
Posted on April 03, 2017 at 10:45
Hello ,
Did you have SPC5-UDESTK Token ?
Easiest and fastest way.
if yes ,
There is Application example inside Chibios + SPC560B Example (Generate and Compile)
  • You can use PLS-UDE to Flash (Link on Slide 4)
http://www.st.com/content/ccc/resource/sales_and_marketing/presentation/product_presentation/8b/be/80/18/4d/1c/4f/f0/SPC56%20Toolchain_overview.pdf/files/SPC56%20Toolchain_overview.pdf/jcr:content/translations/en.SPC56%20Toolchain_overview.pdf
   Install it and the driver associated
  • Reswitch to SPC5Studio to debug .. the flash programming should open
if not ,
Could you give me your Serial/Usb Dongle name that you use ?
   Best regards
                    Erwan
Posted on April 03, 2017 at 18:08
Hi Erwan,
Thanks for your answer.
No, I don't have a SPC5-UDESTK token yet. I ordered it but didn't receive it yet.
I don't understand why would you need the dongle name but it is  Keyspan serial/usb dongle.
regards,
Jorge
Posted on April 03, 2017 at 18:11
Also, requested last Friday activation keys for SPC5FlashProgrammer and SPC5ConnectExplorer through the installation wizard. I haven't received any email or confirmation or serial or anything. What is the normal process?
