i got error as busheavy in pcan view.please help me
ppate.16
respected sir,
i am using SPC560B54L5 and i am testing can protocol in pcan view i got error busheavy status . i am also checking on oscilloscope only getting rx signal from transceiver. CAN interface connection0690X0000087jlSQAQ.pngis like from pcan to transceiver and transceiver to mcu please check attached pic & help me for fixing the problem thanks in advanced.
Erwan YVIN
Hello ,
BUSHEAVY is maybe more than 128 Errors.
it could be a configuration issue (baudrate or something else ..)
It is better to use the debugger and to check why the bus is heavy.
You should check your driver
Best regards
Erwan
3 REPLIES 3
Erwan YVIN
Hello ,
Best regards
Erwan
AvaTar
Lead
Check the cabling and termination.
I got similar issues with missing termination resistor.
i used 2 resistor of 100 ohms in series connection, is it ok ?
