I am not sure why this error raised in spc5studio 5.8.1. Could someone please help with this.
RRama.8
Make error
Erwan YVIN
Hello ,
Could you send me your installation details ?
Have you updated the PATH environment in SPC5Studio configuration
Normally , Gnu Tools (Make) is present in the SPC5Studio Core Package
Best Regards
Erwan
6 REPLIES 6
Erwan YVIN
Hello ,
Best Regards
Erwan
RRama.8
Thanks forthe help.
I installed 5.8.1, I have custom updates especially for our company i tried installing that and i got the error.Due to firewall issues i cannot download from the site.
Erwan YVIN
Hello ,
Sorry for that , IT Proxy is a nightmare for developers.
i can not provide you the offline package of this custom updates
You can create some local mirrors by using eclipse mecanism of P2 repositories by using eclipse commands.
https://www.bsi-software.com/en/scout-blog/article/local-p2-mirrors-to-work-offline.html
This week , we have pushed a new update
Best regards
Erwan
RRama.8
Thank you and i will try that.One more question please.Is ther any way to print stuffs without using external display or something in Chorus 10m.The custom message which are stored in sd_lld_write.
Erwan YVIN
Yes ,
you can use sd_lld_write or Runtime components
There are some example in SPC5Studio Application wizard
Best regards
Erwan
PParf.1
Year Later...
I installed the 5.8.1 from scratch. Previously was working on 5.7.2 without problem. Now i have the same problem as RRama.8. Change path ? Where ? How ? It does not work. Gnu tools are not available.
