missing-QuestionPost
SPBTLE-RF + FreeRTOS
Hallo,I'm a student and I would like to design a product with the SPBTLE-RF module.I have a Nucleo64-401RE and the X-NUCLEO-IDB05A1 board.Using CubeMX I can successfully recreate the SensorDemo application.For my own design I started gethering some c...
attemptx by Associate II
  • 846 Views
Can SPV1040 Be Used with a Single Solar Cell?
The data sheet and application note for SPV1040 appear to be written on the assumption that the driving solar array has an MPTP output voltage of 2.0V or greater. However, I notice that great pains have been taken during the design of the SPV1040 t...
JOlso.12 by Associate III
  • 899 Views
  • 5 replies
Problem pairing a nRF52832 module with a SPBTLE_RF module
We are working with the SPBTLE_RF module with a custom board based on a STM32L082. We need to connect with a module which is based in the nRF52832 of Nordic, the module is the PTR5618.We have done some tests with the STEVAL-IDB007V1M and the BlueNRG_...
Connect to the SPBTLE-1S module with PC
Dear ST teamI would like to ask you, how should I properly connect the module SPBTLE-1S to Windows 10 PC. I found in the document UM2264 (chapter 4.2.5 Using BlueNRG-1 Flasher utility with other boards) instructions how to connect it to PC and pro...
How to Debug SPBTLE-1S modules ?
Hello,Am I correct that there is no possibility to debug the bluetooth module with the current Atollic Truestudio v9.x ? Do you know of any other toolchains which support debugging for these modules ? Best regardsPhilipp
