ADC synchronization problem.
ADian
I have ADC synchronized with PWM and it saves data to buffer. PWM is set to be stopped at debugging. It works well until stop at breakpoint.
​When I debug program and start from breakpoint, the ADC generates incorrect sequence.
How can I fix it?
Can I stop ADC at debugging?
Thank you.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
4 REPLIES 4
Erwan YVIN
Hello Anton ,
I am going to check with experts.
Best regards
Erwan
Erwan YVIN
Which SPC5 family do you use ?
ADian
Hello Erwan,
Thank you for your reply.
I use SPC560P34​
Erwan YVIN
Hello Anton ,
When the SW is stopped,if PWM HW triggers are still active,ADC will go on to convert which HW trigger event.
Therefore, to debug 2 solution :
-         no HW trigger group active (call Adc_DisableHardwareTrigger for each active group)
Or
-         Disable all PWM signals which trigger the CTU for ADC
Best regards
Erwan
