Unable to run code on SPC560B40L3
AChan.5.20
Hello
   I was trying to run Sample Test Code from application wizard into my ECU(SPC560B40L3) but it doesn’t worked out.
I’ve attached the snapshot. Could you please help me out into this?
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
Hello ,
it seems to be a crash issue
check LR,R14 in the debugger to check where the crash is located.
the error display c:\SPC5Studio\tmp
are you the right to access to this directory ?
Best regards
Erwan
1 REPLY 1
Erwan YVIN
Hello ,
Best regards
Erwan
