2015-06-16 10:45 PM
For an upcoming project, I would like to use the SPC56EL54L3 controller. But when I was setting up a SPC5 Studio project, I can´t choose this controller in the platform settings because it is not listed. Is there a reason why this controller isn´t implemented in the ''Specific Model'' in platform component configuration? Best regards, PatrikSolved! Go to Solution.
2015-06-18 02:05 AM
Hello Patrik ,
for your information , the file is present on sourceforge too (SPC5-HAL Project) it should be present in the next delivery Best regards Erwan2015-06-17 02:36 AM
2015-06-18 01:52 AM
Hello Erwan,
Thanks for the quick response. In your post, you write about the patched plugin.xml file. I think you forgot to attach the file to your post. Please can you post this file? Best regards, Patrik2015-06-18 01:59 AM
2015-06-18 02:05 AM
Hello Patrik ,
for your information , the file is present on sourceforge too (SPC5-HAL Project) it should be present in the next delivery Best regards Erwan2015-06-18 06:14 AM
Hello Erwan,
Thanks, that solved my issue! Best regards, Patrik
