SPC56EL54L3 not implemented in ''Platform Settings''
Patriks
Posted on June 17, 2015 at 07:45
For an upcoming project, I would like to use the SPC56EL54L3 controller. But when I was setting up a SPC5 Studio project, I can´t choose this controller in the platform settings because it is not listed.
Is there a reason why this controller isn´t implemented in the ''Specific Model'' in platform component configuration?
Best regards,
Patrik
Erwan YVIN
Posted on June 18, 2015 at 11:05
Hello Patrik ,
for your information , the file is present on sourceforge too (SPC5-HAL Project)
http://sourceforge.net/p/spc5-hal/code/HEAD/tree/trunk/SPC56ELxx/SPC56ELxx_Platform_Component/plugin.xml
it should be present in the next delivery
Best regards
                      Erwan
5 REPLIES 5
Erwan YVIN
Posted on June 17, 2015 at 11:36
Hello Patrik ,
Yes , we have forgotten the enum device for SPC56EL54L3 in the platform settings.
we will integrate it in the next release of SPC5Studio.
in the attachment , you can put the file plugin.xml ''patched' in this following directory
it works on SPC5Studio 3.5.
c:\SPC5Studio\eclipse\plugins\com.st.tools.spc5.components.platform.spc56elxx_XXXXXXXXXXX\
XXXXXXXXX is the last qualifier date.
       Best regards
                  Erwan
Patriks
Posted on June 18, 2015 at 10:52
Hello Erwan,
Thanks for the quick response. In your post, you write about the patched plugin.xml file. I think you forgot to attach the file to your post. Please can you post this file?
Best regards,
Patrik
Erwan YVIN
Posted on June 18, 2015 at 10:59
Oups ,
file in attachment
Best regards
Erwan YVIN
________________
Attachments :
plugin.xml : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0TA&d=%2Fa%2F0X0000000bZF%2FgzsEwkrSyPBxcpe7egJv52XXSRq2jiRN9wyQiTBrFXw&asPdf=false
Erwan YVIN
Hello Patrik ,
Best regards
                      Erwan
Patriks
Posted on June 18, 2015 at 15:14
Hello Erwan,
Thanks, that solved my issue!
Best regards,
Patrik
