2021-06-09 09:36 PM
Installed SPC5Studio on an older WIN7 laptop. When trying to start the application an icon briefly appears in the taskbar - then nothing.
Error log reads "A fatal error has been detected by the Java Runtime Environment..."
Updated existing JAVA runtime environment - same
Uninstalled JAVA - same
Uninstalled and re-installed SPC5Studio - same
Will attach the error log if anyone can work out what is going wrong here and how to fix this.
Thanks - Peter N
2021-11-18 02:08 AM
Hello PNink ,
Sorry , i miss your post.
GraalVM (JRE 11) is crashing in your environment.
could you replace GraalVM version with 11.0.2
in c:\SPC5Studio-6.0\eclipse\jre\
Best Regards
Erwan
2021-11-18 02:08 AM
Hello PNink ,
Best Regards
Erwan
2021-11-18 02:56 PM
Thanks Erwan,
We stopped designing with SPC5 MCUs - not worth the hassle when you can't get support...
Regards, Peter
2021-11-19 12:44 AM
Sorry , but Win7 is considered like an obsolete OS.
in your configuration,
Host: Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz, 8 cores, 7G, Windows 7 , 64 bit Build 7601 (6.1.7601.24545)
it could be good to switch into Win10 😉
Best Regards
Erwan
