X-NUCLEO-IKS01A3 code
RF
Can you help me to use the LSM6DS0 sensor in the IKS01A3 board with the nucleo f767ZI
5 REPLIES 5
What "help", exactly, do you need?
The fact that it's on an X-NUCLEO-IKS01A3 board won't make any difference to its operation ...
Did you look at the 'Tools & Software' tabs on the Product Pages:
Board: https://www.st.com/en/ecosystems/x-nucleo-iks01a3.html#tools-software
Chip: https://www.st.com/en/mems-and-sensors/lsm6dso.html#tools-software
In particular, the X-CUBE-MEMS1, and/or C-Driver-MEMS packs?
https://www.st.com/en/embedded-software/x-cube-mems1.html
https://www.st.com/en/embedded-software/c-driver-mems.html
I’m trying to replicate the project from this link: How to perform motion sensing on STM32L4 IoT Node. I successfully implemented the AI part, and it works properly. However, I encountered issues with the MEMS part. The wiki uses the LSM6DSL sensor, but in my case, I have the IKS01A3 board with the LSM6DSO sensor, and unfortunately, I couldn’t find a tutorial for this setup.
Could you please provide guidance or resources for configuring the LSM6DSO on the IKS01A3 board?
Thank you!
@RF wrote:
I’m trying to replicate the project from this link: How to perform motion sensing on STM32L4 IoT Node.!
So that's using X-CUBE-MEMS1:
Hi, as i explained before i used already xcube MEMS1but i cant find the right code for the LSM6DSO,
thank you
It's there in the supported devices list - both the LSM6DSO chip itself and the X-NUCLEO-IKS01A3 board:
