Why can't I send an app to my SensorTile using ST BLE Sensor and Create Apps on iOS?
‎2019-06-22 3:04 AM
For my SensorTile, when I open the ST BLE Sensor app then create/use an app in Create Apps and tap Play, I get a "Board scanning has timed out" error message. Everything under "Connect to a device" interacts happily with the SensorTile. What's the problem?
I'm using the ST BLE Sensor app v 4.4.3 on iOS.
Thank you.
‎2020-03-18 7:49 AM
More good news! Sorry about the small print, but I have sensor data (Date/Time/Temp/rH & Pressure) logged to the SD card at a period of 996ms. I don't seem to be able to get any slower (yet) but that's fine for my tests. Expert mode->build new App by taking log SD app and changing parameters then saving as a new app.
‎2020-03-18 9:39 AM
Looking much better. I have set the update to 30 seconds. It is near enough!
Updating the App seems to be more reliable at a distance of 3m. Again, it would be handy to be able to debug the upload failures one day.
Anyway, it downloads a new app most of the time and here are the latest results. 30 sec update log...
‎2020-03-19 7:39 AM
‎2020-03-19 12:52 PM
Hi Eleon,
Thanks for 335. I will try it tomorrow, and let you know how I get on.
Al
‎2020-03-20 3:44 AM
I have tried 3.3.5 but it is still unreliable on the Nexus 4. I cannot download an app in expert mode.
I had to use the USB programmer to get 3.3.5 into the SensorTile because 3.3.4 would not do a software upgrade via BT: it kept failing at random parts of the 700k file,
I can load the barometer app.
All variables show Not available for temp, pressure and humidity.
The SD card has not extra files. Just a defaultapp.json plus the ouptxxx.csv files
Can you stream the BT data into an SD file? Plus the reason for failure?
Then it would be easy to debug.
I have rebooted the Nexus and board, but will do that later and see if things work any better.
Alister
‎2020-03-20 9:56 AM
Hi Eleon,
I see in the source code for OTA.C that there is an OTA_PRINTF function. How do I use that?
‎2020-03-28 4:58 AM
Hi Eleon,
SensorTile.box_BL_v334 is more reliable. Please could I have the source code for it?
‎2020-03-30 2:19 AM
Hi @AWatt.1​ , under which point of view do you think the v334 is more reliable than v335? About the initial firmware upgrade or about the BLE connection / applications working with Nexus 4? I can attach you the SensorTile.box_BL_v334 version here below, but in general I suggest you to upload a new FW with the ST programmer in DFU mode.
Yes, of course. You can as 1st step use the Datarecorder example. Please note that to see your ST.box as a mass storage device you have to disconnect your app BLE connection.
‎2020-03-30 2:51 AM
With the Nexus 4 I could not download many apps. I will do full tests later today and let you know what happens with 334 and 335 on the Nexus 4. I have a small job to do testing AVR flash. Back soon!
‎2020-03-30 7:40 AM
I have had a long play with 335. Tests335B is a text file with what I have done, so far.
Programming screen shots, in the wrong order!
