Which Sensor should I use?
smhhadima
Posted on April 08, 2018 at 08:59
I need a sensor that is able to differentiate between distance 20mm and 23mm with no error.
i.e. the accuracy and stability must be high (within 1mm only)
which sensor should I use VL6180 or VL53L or something else?
John E KVAM
Posted on May 02, 2018 at 00:09
Ouch that's a hard one. All the ST Time of Flight sensors return about +/- 3%. So clearly that is outside your limit. But buy the VL53L1X evaluation kit. Go with a very long integration time - (timing budget). If you can condition your target (and it's not some random thing, you should be able to get close. I have a customer doing a medical device with the VL53L0X and he gets within 2mm. So if you have a consistent distance, and a consistent target, you should be able to come very close.
As a rule the ToF sensors can be low power, high accuracy or long distance. But you only get one of those.
In your case, you didn't mention power, need high accuracy and aren't worried about distance.
So go with the VL53L1X and use a long timing budget.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
1 REPLY 1
John E KVAM
