2021-06-12 1:37 PM
Hello everyone,
I am looking for the best IMU to use for a robotics project and I cannot decide which iNEMO is better.
If I compare ASM330LHH, ISM330DHCX, ISM330DLC, LSM6DSRX it's hard to tell which one will perform better.
I am looking for the one that have the best performance (gyro+accel )in term of stabilisation and thermal drift and does not need to be recalibrated often.
Power consumption, price, package, industrial/automotive rating and feature such as NN/Machine learning does not matter, I will mainly use the raw data and do the filtering on an external processing unit.
I did not find any comparaison between all of them, let me know if you any info that could help.
Thank you
2021-06-21 8:00 AM
Hi @Alder748159 ,
the best mechanical performances among the 4 devices you mentioned are the one of LSM6DSRX.
You can compare the respective pages across the datasheets, or refer to the iNemo-Inertial modules product selector (LINK:( you can filter for the mechanical characteristics only.
I attach the search output for simplicity.
-Eleon
2021-06-21 8:00 AM
Hi @Alder748159 ,
-Eleon
