2021-07-15 01:32 AM
2021-07-15 08:04 PM
You can use Cartesiam software solution if you want to run AI at MCU level while you can use MLC if you want to run AI at sensor level. The choice can be made based on the current consumption requirements of the node and the AI model that the user wants to implement.
2021-07-15 08:04 PM
