JTam.1
What is the flow chart to get the Acc X Peak/Acc Y Peak/Acc Z Peak in ST BLE App?
  • August 13, 2021
  • 4 replies
  • 1709 views
Hi , I am using ism330dhcx vibration sensor to measure vibration acceleration on motor. The sensor outputs LSB to MCU, then MCU used it to calculate the actual acceleration in mg (LSB * sensitivity). What is the simple flow chart to get the Acc X Peak/Acc Y Peak/Acc Z Peak? By average acceleration data or something else? Please advise. Thanks!
    Best answer by Eleon BORLINI
    Hi @JTam.1​ ,
    can I refer to this other post?
    I'm asking internally for a precise answer and let you know asap.
    So far, you can consider the values as the output of the MotionSP library: the acceleration peak data are averaged in a window defined by tau and lambda, as described theoretically in this whitepaper.
    -Eleon
    Eleon BORLINI
    Eleon BORLINIBest answer
    Hi @JTam.1​ ,
    -Eleon
    JTam.1
    JTam.1Author
    Hi Eleon, ok. Looking forward to your reply!
    Eleon BORLINI
    Hi @JTam.1​ ,
    I replied in the other post, so if you agree I close this one.
    -Eleon
