2021-08-09 4:47 AM
Hello, did ST ever made a STE150N10 direct (Drop in) replacement?
if so, what would be the partnumber?
thanks
2021-08-09 6:46 AM
No, there is no exact replacement.
You could try a similar MOSFET in exactly the same package, but slightly different parameters: the STE140NF20D, which is already on status NRND (Not Recommenced for New Design).
Good luck!
/Peter
2021-08-09 6:46 AM
Good luck!
/Peter
