What is IIS2ICLX accuracy and resolution?
DChou.2
Can IIS2ICLX able to provide 3 Min of arc Accuracy and resolution? My application need 3 Min of arc accuracy and 1 min of arc resolution, is IIS2ICLX sensor capable to provide that with calibration?
*Edited by moderation, please keep the title of your question shorter than 70 characters*
Eleon BORLINI
Hi @DChou.2​ ,
I'm not sure you can get the 0.05deg resolution (since the resolution also depends on the tilt angle itself), but I suggest you to check this DT0140 Design tip which describes the tilt computation using accelerometer data for inclinometer applications involving IIS2ICLX device.
-Eleon
