What does circular burst-mode (rounding) read from the output registers mean?
2019-11-27 3:23 PM
I am implementing the IIS3DWB vibrometer. There is a register that allows circular burst-mode (rounding) read from output registers. What does it mean?
Thanks.
2019-11-28 7:43 AM
Hi @DLim.16 , burst-mode read is a one-shot / single data output read. The circular burst-mode (rounding) read function is used for automatically rounding from address FIFO_DATA_OUT_Z_H to FIFO_DATA_OUT_TAG in the device in order to allow user to read many data with a unique multiple read. The ROUNDING<1:0> bits are used to auto address the correct registers for a circular burst-mode read of the device following one of the following patterns:
00 = no rounding
01 = XL only (no Temp)
Btw, IIS3DWB is in evaluation status... where did you get the datasheet? Regards
