2018-03-07 5:58 AM
Hello Sir/Madam,
Currently we are looking for angle measurement sensor.
for this we thought that gyroscope will be best option. if we thing something wrong then let us know.Now come to the point, We required angle measurement sensor which has high accuracy and we required angle data with minimum tolerance.Its good if anyone has sensor detail or part no. with tolerance in term of angle.##accelarometer ##gyroscope ##angle ##axis-sensor2018-03-07 9:35 AM
The angle of what vs what? Rotating around what? What level of precision/accuracy/repeat-ability?
Could you use a mechanical sensor with an encoder?
Your question is rather lacking for any sort of useful engineering/design suggestion.
