VL6180X and VL53L0X (Pololu) reliably sense to 0.5 to 1mm. Goal: sense changes to 0.001inch / 0.025mm for measuring table movement of small lathes/mills.
LBahn.1
Is there a TOF sensor product / software solution that can obtain 0.001inch measurement precision?
Thanks in advance.
1 REPLY 1
John E KVAM
A round trip of 1mm uses 6.7 pico seconds. And a pico second as you know is one millionth of one millionth of a second. And the vl53 sensors are only a few dollars.
As much as I'd love the sensor to have accuracy that good, it just isn't going to work.
I'm afraid for your application a dial indicator is still the best way to go.
  • john
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
