Unicleo and Algobuilder download links
‎2020-11-06 03:08 AM
Hi! I am currently trying to download Algobuilder and Unicleo. I tried in different browsers and also on different PCs. The download links are not displayed as expected. CubeIDE was working, I could get the software.
Can sombody check if this in only on my side?
‎2020-11-06 04:30 AM
Hi @DWind.1​ ,
you are right, these softwares are currently not available for the download since they are under upgrade in a new solution coming soon.
If you however urgently need these tools, the overall zip file is a little big but I try anyway to attach it here below.
You may give me some feedback as beta tester about it, if you want.
-Eleon
‎2020-11-06 04:33 AM
HI Eleon!
Thanks for the answer and the package. Is there anything that you can already share regarding this new solution?
Indeed we would be interesting in testing the solution alread in a beta phase.
Best wishes,
Dominik
‎2020-11-06 05:13 AM
Hi Dominik,
thank you for your availability.
What I can share you so far is the package inside the zip file attached to my last comment (or at leas should be since it is quite heavy...)
-Eleon
