Trouble with LSM6DS3's accelerometer Z & Y axis outputs in SPI mode
ASHNO JAMES
Posted on December 23, 2016 at 07:27
I am new to LSM6DS3 inertial module, I am trying to use it with my arduino mega 2560, in SPI mode ,but in trouble with  Z & Y axis output of the accelero meter. X axis output respond well.
Already tried to read the output raw registers with and without reading the STATUS Register, but the result remains same.  I bought the breakout board from Sparkfun and made necessary changes for using this in SPI mode. Attaching my arduino code with this post.
Miroslav BATEK
Posted on December 23, 2016 at 14:33
Which values did you get from Y and Z axis?
I would suggest to set BDU bit in CTRL3_C to 1, to have aligned high and low part of data registers.
I see you are reading the X value twice. Is it intentional?
Posted on December 23, 2016 at 15:43
Changed the value in CTRL3_C to 0x41  , attaching the images of output values of x,y,z of accelero  , all axis are tested with +1g, x gives perfect output, z and y gives some valid output when i give some knock on the table where sensor board is placed.0690X00000605xHQAQ.png0690X00000605xMQAQ.png0690X00000605poQAA.png
