STTS22H - what is the temperature registers format?
2020-04-19 2:49 PM
I may be exceptionally dumb, but I can't find in the STTS22H DS, how can the measured temperature be determined from the values read from the temperature registers.
What am I missing?
2020-04-20 4:35 AM
Hi @Community member , you can also refer to the online available C drivers (github link) for the conversion between LSB (concatenate TEMP_H_OUT and TEMP_L_OUT) and °C in STTS22H
float_t stts22h_from_lsb_to_celsius(int16_t lsb)
return ((float_t)lsb /100.0f);
2020-04-20 1:13 AM
2020-04-20 4:35 AM
2020-04-20 4:39 AM
Hi @Eleon BORLINI ,
Okay; but isn't the DS the primary source which ought to contain this information?
And, once we are at it, what's exactly the meaning of BDU bit in CTRL register?
Frank, @KnarfB ,
Yes, that DS - can you see in there how to interpret the values read out of the TEMP_L_OUT/TEMP_H_OUT registers?
Thanks,
2020-04-20 6:53 AM
Hi @Community member , technically you are not wrong... I'll report it to the product champion. Thank you for your note. Regards
2020-04-20 7:00 AM
Thanks, @Eleon BORLINI .
Jan
2020-04-27 8:21 AM
Hi Jan, after an internal check we should be able to add in the next datasheet revision a paragraph explaining in a clearer way the temperature readings interpretation, similar to the below-shown LPS22HH's one:
2020-04-27 10:44 AM
