STM32F103xC and LM35 wrong readings
2021-04-10 3:41 PM
Hey, I'm trying to get some temperature readings from LM35 sensor and I'm using "blue pill" for this little project and of course ADC. The problem is that I am getting wrong readings, approximately half of the real value. I know that the sensor is good because I tested it with arduino nano and well it gave me right values.
void ADC()
error= HAL_ADC_Start(&hadc1);
if(error!=HAL_OK)
i=1;
error=HAL_ADC_PollForConversion(&hadc1,1);
if(error!=HAL_OK)
i=2;
i=3;
Adc_Value = HAL_ADC_GetValue(&hadc1);
Reiksme=(Adc_Value*3.3)/(4096*0.01);
HAL_Delay(1000);
here is my little function to get those values. Any ideas why it doesn't work on this mcu?
ADC
2021-04-12 2:15 AM
Proposals:
- please check AN2834
- please check your ADC settings, e.g. clock, sampling time
- calibrate the ADC using a HAL_ADCEx_Calibration_Start
- test an increased timeout of e.g. 10ms by HAL_ADC_PollForConversion(&hadc1,10);
And please also check VCC, as you are referring to a fixed value of 3.3V when calculating, e.g. by measuring the internal reference voltage.
2021-04-12 12:39 AM
I assume you get the supply voltage of the LM35 from VCC of the STM32F103, right?
The LM35 is a analoge centigrade temperature sensor requiring a supply voltage of 4...30V. It will work if you supply it with 5V like you did with Arduino.
Good luck!
/Peter
2021-04-12 12:47 AM
Yeah, I'm using supply voltage from my STM32. I tried connecting different source of 5V but it still does not work properly. I tried measuring signal voltage with a multimeter and got correct voltages ( around 200 mV in 20 °C temperature) so I it's got to be mcu problem with converting.
2021-04-12 2:15 AM
Proposals:
