2023-11-22 08:43 AM
Thanks,
2023-11-23 03:13 AM
Welcome @Tiphaine, to the community!
The STHS34PF80 is a sensor for presence and motion detection, it is not an image sensor whose image data could be read out as raw data. It is also not designed to count several people, you would probably have to use a real camera with subsequent image processing.
Does it answer your question?
Good luck!
/Peter
2023-11-23 03:13 AM
Good luck!
/Peter
