2024-01-22 09:41 AM
I have a custom PCB for my company for automotive purposes with the ASM330LHHX as the IMU. Upon integrating the gyro rate (about the X axis, roll rate, see green line in 1st plot below) while acceleration is happening on the on the Y axis (Ay, see orange trace in second plot below), the purely integrated angle estimate diverges significantly more than it does otherwise without the Ay. This data is from a car driving around sporatically with some significant Ay events in both directions.
What is the cause of this behavior from the gyro? Is there a specification that determines how much this behavior occurs, in a standard format of SI units?
Thank you,
Steve Krug
CTO
steve@axicleengineering.com
2024-01-29 04:18 PM
Thank you for the response Federica. I believe this may have been due to an error in my software, in fact. Thank you for the response anyways.
2024-01-25 04:46 AM
Hi @slkrug ,
From these graphs is difficult to understand what could be, surely this behavior is unexpected..
Can you give more details about your log scenario?
2024-01-29 04:18 PM
