2019-05-14 06:09 AM
Any known issues with soldering a STLKT01V1 (sensor tile ) to the small carrier board?
I did this, and now it does not work (no jtag) it worked prior with large board
I do not want to destroy a 3rd board!
2019-05-22 07:39 AM
Hi, do you refer to this action?
I suggest you to center the SensorTile fixing it on the STLCR01V1 cradle main component with e.g. tape or a clip, put flux on the exposed pads and then solder the structure. Please use flux and an appropriate welder
Please check also the presence of any short due to the soldering process.
2019-06-03 05:50 AM
yes
