2014-10-07 8:21 PM
how to integrate ST�s pressure sensors and humidity sensors in Linux/Android systems?
#pressure-humidity-sensors2014-10-10 12:52 AM
The application note AN4503 explains how to integrate the STMicroelectronics environmental sensor in Linux/Android systems. It provides detailed information and procedures on how to manage this task.
The configuration files of the sensor HAL (hardware abstraction layer) are also discussed along with the issues and possible solutions for successfully integrating different kinds of sensors.
Finally, the building and installation of this library is also described.
http://www.st.com/web/en/resource/technical/document/application_note/DM00118439.pdf
Best Regards
