2020-10-22 12:45 PM
I'm using the LIS2DH at a 10 Hz sample rate and need to change it to 400 Hz. How will this change power consumption of the device?
2020-10-23 04:26 AM
Hi @RobH ,
you can find the detailed table of the LIS2DH power consumption in the datasheet, p.17:
In your case, depending on your mode, you can have the following power consumption variations:
Let me please know if it is enough for your scope.
-Eleon
2020-10-23 04:26 AM
Hi @RobH ,
-Eleon
