nucleo-gui can connecet uart port,but can not statrt
‎2020-05-19 8:04 PM
nucleo-gui can connecet uart port,but can not start, like follows
1.nucleo borad: nucleo-l4r5zi , mems borad: iks01a2
2. using X-CUBE-MEMS1 7.10 gesturerecognition appliction
3.
anyone know what is problem? thank you?​
‎2020-05-21 1:17 AM
the problem I see is wrong settings of the Baud Rate for the communication port LPUART1. It should be 921600.
Unfortunately, I don't have this NUCLEO-L4R5ZI right now so I can't check it on real hardware. So please try to change the Baud Rate.
‎2020-05-20 7:12 AM
would you please attach your ioc file from CubeMX so we can check it?
Which IDE you use? Was the compilation without any error or warning?
‎2020-05-20 8:46 PM
‎2020-05-21 1:17 AM
‎2020-05-21 2:29 AM
It is ok now. Thank you very much. I love you so much,谢谢�?
‎2020-05-21 2:32 AM
