2022-05-30 12:11 AM
Dear all,
Thanks.
2022-06-03 06:12 AM
Hi @E-John ,
your calculation is in theory correct, but consider that for avoiding nonlinearities at the edge of the sensor full scale, the actual sensitivity is greater than the "digitally calculated" sensitivity. It also takes into account gain coefficients that are calibrated at production level.
Please consider the datasheet value as the correct one for the LSB to physical units conversion.
-Eleon
2022-06-03 06:12 AM
Hi @E-John ,
-Eleon
2022-06-03 08:01 AM
Hi Eleon,
Understood. Thanks for your explanations.
E-John
